Datasheet LM2902NG - ON Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, DIP-14 — Даташит
ON Semiconductor LM2902NG
Наименование модели: LM2902NG
IC OPAMP GP 4 CIRCUIT 14DIP. General Purpose Amplifier 4 Circuit 14-PDIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LM2902NG4
3.48 ₽
LM2902NG
21 ₽
727GS
LM2902NG
от 57 ₽
LifeElectronics
LM2902NG
Производитель: ON Semiconductor
Описание: ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, DIP-14
data sheetСкачать Data Sheet
LM324, LM324A, LM224, LM2902, LM2902V, NCV2902 Single Supply Quad Operational Amplifiers
The LM324 series are low-cost, quad operational amplifiers with true differential inputs.
They have several distinct advantages over standard operational amplifier types in single supply applications. The quad amplifier can operate at supply voltages as low as 3.0 V or as high as 32 V with quiescent currents about one-fifth of those associated with the MC1741 (on a per amplifier basis). The common mode input range includes the negative supply, thereby eliminating the necessity for external biasing components in many applications. The output voltage range also includes the negative power supply voltage.
Features http://onsemi.com
PDIP-14 N SUFFIX CASE 646 14 1 SOIC-14 D SUFFIX CASE 751A
  • Тип ОУ: Low Bias Current
  • Количество усилителей: 4
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.6 В/мкс
  • Диапазон напряжения питания: 3 В ... 32 В
  • Тип корпуса: DIP
  • Количество выводов: 14
На английском языке: Datasheet LM2902NG - ON Semiconductor IC, OP-AMP, 1 MHz, 0.6 V/µs, DIP-14
