Datasheet LM324DR2G - ON Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, SOIC-14 — Даташит
Наименование модели: LM324DR2G
Производитель: ON Semiconductor
Описание: ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, SOIC-14
LM324, LM324A, LM224, LM2902, LM2902V, NCV2902 Single Supply Quad Operational Amplifiers
The LM324 series are low-cost, quad operational amplifiers with true differential inputs.
They have several distinct advantages over standard operational amplifier types in single supply applications. The quad amplifier can operate at supply voltages as low as 3.0 V or as high as 32 V with quiescent currents about one-fifth of those associated with the MC1741 (on a per amplifier basis). The common mode input range includes the negative supply, thereby eliminating the necessity for external biasing components in many applications. The output voltage range also includes the negative power supply voltage.
Features http://onsemi.com
PDIP-14 N SUFFIX CASE 646 14 1 SOIC-14 D SUFFIX CASE 751A
- Тип ОУ: Low Bias Current
- Количество усилителей: 4
- Полоса частот: 1 МГц
- Скорость нарастания: 0.6 В/мкс
- Диапазон напряжения питания: 3 В ... 32 В
- Тип корпуса: SOIC
- Количество выводов: 14
