Datasheet NCP4300ADG - ON Semiconductor Даташит ИС, операционный усилитель, 700 кГц, 0.5 В/мкс, SOIC-8 — Даташит
Наименование модели: NCP4300ADG
Купить NCP4300ADG на РадиоЛоцман.Цены — от 22 до 977 ₽17 предложений от 17 поставщиков Микросхема Операционный усилитель, ON SEMICONDUCTOR NCP4300ADG Operational Amplifier, Dual, 2 Amplifier, 700kHz, 0.5V/µs, 3V to 35V, SOIC, 8Pins | |||
| NCP4300ADG | 23 ₽ | ||
| NCP4300ADG ON Semiconductor | по запросу | ||
| NCP4300ADG/ADR2G ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, операционный усилитель, 700 кГц, 0.5 В/мкс, SOIC-8
NCP4300A Dual Operational Amplifier and Voltage Reference
The NCP4300A is a monolithic integrated circuit specifically designed to control the output current and voltage levels of switch mode battery chargers and power supplies.
This device contains a precision 2.6 V shunt reference and two operational amplifiers. Op-Amp 1 is designed to perform voltage control and has its non-inverting input internally connected to the reference. Op-Amp 2 is designed for current control and has both inputs uncommitted. The NCP4300A offers the power converter designer a control solution that features increased precision with a corresponding reduction in system complexity and cost. This device is available in an 8-lead surface mount package.
Features http://onsemi.com MARKING DIAGRAM
8 8 1 SOIC-8 D SUFFIX CASE 751 1 A L Y W A G N4300 ALYWA G
· This is a Pb-Free Device
- Тип ОУ: General Purpose
- Количество усилителей: 2
- Полоса частот: 700 кГц
- Скорость нарастания: 0.5 В/мкс
- Диапазон напряжения питания: 3 В ... 35 В
- Тип корпуса: SOIC
- Количество выводов: 8
