Datasheet NTE1171 - NTE Electronics Даташит ИС, операционный усилитель, METAL CAN — Даташит
NTE Electronics NTE1171
Наименование модели: NTE1171
14 предложений от 11 поставщиков
Микросхема Операционный усилитель, OP Amp Single GP ±18V 8Pin Metal Can
NTE1171
NTE Electronics
510 ₽
Зенер
Россия и страны ТС
NTE1171
от 1 434 ₽
TradeElectronics
NTE1171
NTE Electronics
NTE-1171
Производитель: NTE Electronics
Описание: ИС, операционный усилитель, METAL CAN
data sheetСкачать Data Sheet
NTE1171 Integrated Circuit Operational Amplifier
Description: The NTE1171 is a general purpose operational amplifier in an 8­Lead Metal Can type package.
Advanced processing techniques make possible an order of magnitude reduction in input currents, and a redesign of the biasing circuitry reduces the temperature drift of the input current. This amplifier offers many features which make its application nearly foolproof: overload protection on the input, no latch­up when the common mode range is exceeded, freedom from oscillations and compensations with a single 30pF capacitor. It has advantages over internally compensated amplifiers in that the frequency compensation can be tailored to the particular application. For example, in low frequency circuits it can be overcompensated for increased stability margin. Or the compensation can be optimized to give more than a factor of ten improvement in high frequency performance for most applications. Feature: D Low Input Offset Current: 20na Max
  • Тип ОУ: General Purpose
  • Количество усилителей: 1
  • Диапазон напряжения питания: ± 5 В ... ± 15 В
  • Тип корпуса: Metal Can
  • Количество выводов: 8
  • Рабочий диапазон температрур: 0°C ... +70°C
На английском языке: Datasheet NTE1171 - NTE Electronics IC, OP-AMP, METAL CAN
