Datasheet NTE937M - NTE Electronics Даташит Operational усилитель (Op-Amp) ИС — Даташит
NTE Electronics NTE937M
Наименование модели: NTE937M
9 предложений от 8 поставщиков
Активная деталь, Amplifier, Operational; +/- 18V; 5mA (Typ.) Supply; +/- 30V; DIP
Элитан
NTE937M
NTE Electronics
3 800 ₽
NTE937M
LifeElectronics
NTE-937M
NTE937M
Производитель: NTE Electronics
Описание: Operational усилитель (Op-Amp) ИС
data sheetСкачать Data Sheet
NTE937M
Integrated Circuit JFET Input Operational Amplifier
Description: The NTE937M is a monolithic JFET input operational amplifier in an 8­Lead DIP type package incorporating well­matched, high voltage JFET's on the same chip with standard bi­polar transistors.
This amplifier features low input bias and offset currents, low offset voltage and offset voltage drift, coupled with offset adjust which does not degrade drift or common­mode rejection. It is also designed for high slew rate, wide bandwidth, extremely fast settling time, low voltage and current noise and a low 1/f noise corner. Advantages: D Replaces Expensive Hybrid and Module FET OP Amps D Rugged JFET's Allow Blow­Out Free Handling Compared with MOSFET Input Device D Excellent for Low Noise Applications using either High or Low Source Impedance ­ Very Low 1/f Corner D Offset Adjust does not Degrade Drift or Common­Mode Rejection as in Most Monolithic Amplifiers D New Output Stage Allows use of Large Capacitive Loads (10,00
На английском языке: Datasheet NTE937M - NTE Electronics Operational Amplifier (Op-Amp) IC
