Datasheet NTE975 - NTE Electronics Даташит ИС, операционный усилитель, DIP-8 — Даташит
NTE Electronics NTE975
Наименование модели: NTE975
21 предложений от 11 поставщиков
Активная деталь, Operational Amplifier, 1 Func, 6000uV Offset-Max, PDIP8, MINI, DIP-8
NTE975
от 120 ₽
NTE975
208 ₽
NTE-975
NTE975SM
NTE Electronics
Производитель: NTE Electronics
Описание: ИС, операционный усилитель, DIP-8
data sheetСкачать Data Sheet
NTE975 & NTE975SM Integrated Circuit Operational Amplifier
Description: The NTE975 and NTE975SM are general purpose operational amplifiers built on a single chip.
The resulting close match and tight thermal coupling gives low offsets and temperature drift as well as fast recovery from thermal transients. The unity­gain compensation specified makes the circuit stable for all feedback configurations, even with capacitive loads. However, it is possible to optimize compensation for the best high frequency performance at any gain. As a comparator, the output can be clamped at any desired level to make it compatible with logic circuits. Features: D Available in 8­Lead Mini DIP (NTE975) and Surface Mount, SOIC­8 (NTE975SM) D Frequency Compensation with a Single 30pF Capacitor D Operation From ±5V to ±20V D Low Current Drain: 1.8mA @ ±20V D Continuous Short­Circuit Protection D Operation as a Comparator with Differential Inputs as High as ±30V D No Latch­Up when Common Mode Range is Exceeded A
  • Тип ОУ: General Purpose
  • Количество усилителей: 1
  • Диапазон напряжения питания: ± 5 В ... ± 20 В
  • Тип корпуса: DIP
  • Количество выводов: 8
  • Рабочий диапазон температрур: 0°C ... +70°C
Дополнительные аксессуары:
  • ON Semiconductor - LM301ANG
На английском языке: Datasheet NTE975 - NTE Electronics IC, OP-AMP, DIP-8
