Datasheet NTE987 - NTE Electronics Даташит — Даташит
Наименование модели: NTE987
Купить NTE987 на РадиоЛоцман.Цены — от 67 до 303 ₽23 предложений от 13 поставщиков IC: операционный усилитель; Ch: 4; SO14; ±1,5÷16ВDC,3÷32ВDC | |||
| NTE987SM | от 212 ₽ | ||
| NTE987SM NTE Electronics | от 224 ₽ | ||
| NTE987SM NTE Electronics | 303 ₽ | ||
| NTE987 | по запросу | ||
Производитель: NTE Electronics
NTE987/NTE987SM Integrated Circuit Quad, Low Power OP Amp
Description: The NTE987 and NTE987SM are low cost quad operational amplifiers with true differential inputs.
These have several distinct advantages over standard operational amplifier types in single supply applications. The quad amplifier can operate at supply voltages as low as 3V or as high as 32V with quiescent currents about one fifth of those associated with the NTE941 (on a per amplifier basis). The common mode input range includes the negative supply, thereby eliminating the necessity for external biasing components in many applications. The output voltage range also includes the negative power supply voltage. Features: D Available in 14-Lead DIP (NTE987) and Surface Mount, SOIC-14 (NTE987SM) D Short Circuit Protected Outputs D True Differential Input Stage D Single Supply Operation: 3V to 32V D Four Amplifiers per Package D Internally Compensated D Common Mode Range Extends to Negative Supply D Industry Standard Pin-Out
- Operational Amplifier IC Mounting Type: T
Дополнительные аксессуары:
- NTE Electronics - NTE987
