Datasheet Texas Instruments OPA234UAG4 — Даташит
СерияOPA234
МодельOPA234UAG4
Маломощные прецизионные операционные усилители с однополярным питанием 8-SOIC от -40 до 125
OPA234, 2234, 4234: Low Power, Precision Single-Supply Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 10 апр 2008
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesVos Adj Pin
Approx. Price (US$)1.40 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)86
CMRR(Typ)(dB)106
GBW(Typ)(MHz)0.35
Input Bias Current(Max)(pA)30000
Iq per channel(Max)(mA)0.3
Iq per channel(Typ)(mA)0.25
Number of Channels(#)1
Offset Drift(Typ)(uV/C)0.5
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)11
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)0.2
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)25
Vos (Offset Voltage @ 25C)(Max)(mV)0.1
RoHSНе совместим
  • Stop-band limitations of the Sallen-Key, low-pass filter
    PDF, 573 Кб, Файл опубликован: 22 окт 2008
  • Q4 2008 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 22 окт 2008
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA234UAG4
