Datasheet Texas Instruments OPA336NA/250G4 — Даташит
СерияOPA336
МодельOPA336NA/250G4
КМОП-операционные усилители MicroPower с однополярным питанием MicroAmplifier™ Series 5-SOT-23
OPA336, 2336, 4336: Single-Supply, microPower CMOS Op Amp microAmplifier Series datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 11 янв 2005
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаA36
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesN/A
АрхитектураCMOS
CMRR(Min)76 дБ
CMRR(Typ)86 дБ
GBW(Typ)0.1 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)0.032 мА
Iq per channel(Typ)0.02 мА
Количество каналов1
Offset Drift(Typ)1.5 uV/C
Output Current(Typ)5 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.03 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)2.3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)40 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.125 мВ
  • Precision Absolute Value Circuits
    PDF, 100 Кб, Файл опубликован: 2 окт 2000
    You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
  • Tuning in Amplifiers
  • Solder Pad Recommendations for Surface-Mount Devices (Rev. A)
    PDF, 91 Кб, Версия: A, Файл опубликован: 28 апр 2003
    Cost and performance requirements continue to push the packaging of electronic systems into smaller and smaller spaces. The advent of surface-mount devices has brought pin spacings that differ from one package series to the next. This application report addresses criteria for well-designed solder joints and provides the design engineer with useful tabular data of some of the more popular packages
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA336NA/250G4
