Datasheet Texas Instruments OPA340NA/3KG4 — Даташит
СерияOPA340
МодельOPA340NA/3KG4
Операционные усилители с одинарным питанием и Rail-to-Rail MicroAmplifier™ Series 5-SOT-23 от -40 до 85
OPAx340 Single-Supply, Rail-to-Rail Operational Amplifiers MicroAmplifier Series datasheet
PDF, 1.9 Мб, Версия: C, Файл опубликован: 20 янв 2016
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаA40
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesN/A
АрхитектураCMOS
CMRR(Min)80 дБ
CMRR(Typ)92 дБ
GBW(Typ)5.5 МГц
Input Bias Current(Max)10 pA
Iq per channel(Max)0.95 мА
Iq per channel(Typ)0.75 мА
Количество каналов1
Offset Drift(Typ)2.5 uV/C
Output Current(Typ)50 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)6 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)25 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • Precision Absolute Value Circuits
    PDF, 100 Кб, Файл опубликован: 2 окт 2000
    You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a
  • A dual-polarity, bidirectional current-shunt monitor
    PDF, 704 Кб, Файл опубликован: 22 окт 2008
  • Q4 2008 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 22 окт 2008
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Tuning in Amplifiers
  • OPA340, OPA2340, OPA4340 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 2 ноя 2012
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA340NA/3KG4
