Datasheet Texas Instruments OPA690IDBVTG4 — Даташит
СерияOPA690
МодельOPA690IDBVTG4
Широкополосный операционный усилитель с обратной связью по напряжению и отключением 6-SOT-23 от -40 до 85
OPA690 Wideband, Voltage-Feedback Operational Amplifier With Disable datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 10 авг 2016
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаOAEI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic68 dBc
3rd Harmonic70 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Voltage FB
BW @ Acl500 МГц
CMRR(Min)60 дБ
CMRR(Typ)65 дБ
GBW(Typ)500 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)5.8 мА
Iq per channel(Typ)5.5 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)190 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailNo
Slew Rate(Typ)1800 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)5.5 нВ/rtГц
Vn at Flatband(Typ)5.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • Evaluation Modules & Boards: DEM-OPA-SOT-1A
    Unpopulated PCB Compatible w/High Speed, Wide Bandwidth Op Amps in SOT(DBV) Pkg
  • Evaluation Modules & Boards: DEM-OPA-SO-1A
    DEM-OPA-SO-1A Unpopulated PCB Compatible w/High Speed Wide Bandwidth Op Amps in 8-lead SOIC (D) Pkg
  • A Numerical Solution to an Analog Problem
    PDF, 210 Кб, Файл опубликован: 25 апр 2010
    In order to derive a solution for an analog circuit problem, it is often useful to develop a model. This approach is generally accepted as developing an analytical model. However, finding the analytical solution is not always practical or possible as a result of higher-degree polynomials that require further resolution, or because of the time needed to develop the solution completely. In these sit
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
На английском языке: Datasheet Texas Instruments OPA690IDBVTG4
