Datasheet Texas Instruments UA741CPE4 — Даташит
СерияUA741
МодельUA741CPE4
Операционный усилитель общего назначения 8-PDIP от 0 до 70
µA741 General-Purpose Operational Amplifiers datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 2 май 2017
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаUA741CP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)70 дБ
CMRR(Typ)90 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)500000 pA
Iq per channel(Max)2.8 мА
Iq per channel(Typ)1.7 мА
Количество каналов1
Output Current(Typ)25 мА
Package GroupPDIP
Rail-to-RailNo
Slew Rate(Typ)0.5 V/us
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)20 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
На английском языке: Datasheet Texas Instruments UA741CPE4
