Datasheet Texas Instruments VCA820ID — Даташит
СерияVCA820
МодельVCA820ID
Полоса пропускания 150 МГц с линейным регулированием усиления в дБ, усилитель с переменным коэффициентом усиления 14-SOIC от -40 до 85
VCA820 Wideband, > 40-dB Adjust Range, Linear in dB Variable Gain Amplifier datasheet
PDF, 2.2 Мб, Версия: D, Файл опубликован: 9 сен 2015
Pin14
Package TypeD
Package QTY50
МаркировкаVCA820ID
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain10 V/V
BW @ Acl150 МГц
Max Gain40 дБ
Количество каналов1
PGA/VGAVGA
Slew Rate(Typ)1700 V/us
Vs(Max)12 В
Vs(Min)7 В
  • Evaluation Modules & Boards: DEM-VCA-MSOP-1A
    DEM-VCA-MSOP-1A
  • Evaluation Modules & Boards: DEM-VCA-SO-1B
    DEM-VCA-SO-1B
  • Implementating a Variable-Length Cat5e Cable Equalizer
    PDF, 505 Кб, Файл опубликован: 25 апр 2010
    Unshielded twisted pair (UTP) cables have long been used to transmit data over long distances, starting with telephone line networks. As a result of the relatively low cost, these cables have also been adopted for various uses including video distribution. All UTP cables attenuate the signal over frequency with maximum attenuation at maximum signal frequency. This attenuation will also increase as
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA820ID
