Datasheet Texas Instruments THS3121CD — Даташит
СерияTHS3121
МодельTHS3121CD
Одиночный, малошумящий, высокопроизводительный усилитель с токовой обратной связью, 475 мА, 8-SOIC -40–85
Low-Noise, High-Output Drive, Current Feedback Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 12 окт 2009
THS3121CD
284 ₽
Рутоника
THS3121CD
443 ₽
Microfind
THS3121CD
1 562 ₽
THS3121CD
Package TypeD
Package QTY75
Маркировка3121C
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic51 dBc
3rd Harmonic50 dBc
@ MHz10
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Current FB
BW @ Acl130 МГц
CMRR(Min)63 дБ
CMRR(Typ)70 дБ
GBW(Typ)130 МГц
Input Bias Current(Max)4000000 pA
Iq per channel(Max)4.25 мА
Iq per channel(Typ)3.5 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)475 мА
Rail-to-RailNo
Slew Rate(Typ)1500 V/us
Total Supply Voltage(Max)30 +5V=5, +/-5V=10
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2.5 нВ/rtГц
Vn at Flatband(Typ)2.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: THS3111EVM
    THS3111 Evaluation Module
  • Evaluation Modules & Boards: THS3120EVM
    THS3120 Evaluation Module
  • Evaluation Modules & Boards: THS3110EVM
    THS3110 Evaluation Module
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS3121CD
