Datasheet Texas Instruments OPA355NA/250 — Даташит
СерияOPA355
МодельOPA355NA/250
2,5 В, 200 МГц GBW, одиночный КМОП-операционный усилитель с отключением 6-SOT-23 от -40 до 125
OPA355, 2355, 3355: 200MHz, CMOS Operational Amplifier with Shutdown datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 6 ноя 2003
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаC55
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
2nd Harmonic81 dBc
3rd Harmonic93 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураCMOS,Voltage FB
BW @ Acl450 МГц
CMRR(Min)66 дБ
CMRR(Typ)80 дБ
GBW(Typ)450 МГц
Input Bias Current(Max)50 pA
Iq per channel(Max)11 мА
Iq per channel(Typ)8.3 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)100 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn to V-,Out
Slew Rate(Typ)300 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)5.8 нВ/rtГц
Vn at Flatband(Typ)5.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)9 мВ
  • Tuning in Amplifiers
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA355NA/250
