Datasheet Texas Instruments OPA1612AID — Даташит
СерияOPA1612
МодельOPA1612AID
SoundPlus™ Audio Operational Amplifier with 1.1nV/в€љHz Noise, Low THD and Precision 8-SOIC -40 to 85
OPA161x SoundPlus High-Performance, Bipolar-Input Audio Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 27 авг 2014
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
Маркировка1612AOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesBurr-Brownв„ў Audio,Tiny Package
АрхитектураBipolar
CMRR(Min)110 дБ
CMRR(Typ)120 дБ
GBW(Typ)40 МГц
Input Bias Current(Max)250000 pA
Iq per channel(Max)4.5 мА
Iq per channel(Typ)3.6 мА
Количество каналов2
Offset Drift(Typ)1 uV/C
Output Current(Typ)55 мА
Rail-to-RailOut
Slew Rate(Typ)27 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • HiFi Audio Circuit Design
    PDF, 252 Кб, Файл опубликован: 23 авг 2017
    With the increase in personal electronic devices, HiFi audio is more popular than ever in many applications, such as smartphones, music players, home theaters, and even car infotainment. Many engineers and consumers devote themselves to the endless journey in HiFi audio. This document will help engineers understand, judge, design, and optimize a HiFi audio circuit.
  • Feedback Plots Define Op Amp AC Performance
    PDF, 89 Кб, Файл опубликован: 27 сен 2000
    Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits.
  • Analog Applications Journal 2Q 2015
    PDF, 2.5 Мб, Файл опубликован: 28 апр 2015
  • Stabilizing difference amplifiers for headphone applications
    PDF, 670 Кб, Файл опубликован: 28 апр 2015
  • Reducing distortion from CMOS analog switches
    PDF, 375 Кб, Файл опубликован: 29 янв 2015
  • Distortion and source impedance in JFET-input op amps
    PDF, 182 Кб, Файл опубликован: 24 окт 2014
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA1612AID
