Datasheet Texas Instruments OPA2111AM — Даташит
СерияOPA2111
МодельOPA2111AM
Двойной малошумящий операционный усилитель Difet® 8-TO-99
Dual Low-Noise Difet® Operational Amplifier datasheet
PDF, 193 Кб, Файл опубликован: 27 сен 2000
21 предложений от 18 поставщиков
OPA2111AM
2 840 ₽
OPA2111AM
2 840 ₽
Элитан
OPA2111AM
7 499 ₽
OPA2111AM
от 8 392 ₽
Package TypeLMC
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Package QTY20
МаркировкаOPA2111AM
Width (мм)9.08
Length (мм)9.08
Thickness (мм)4.4
Pitch (мм)2.54
Max Height (мм)5.72
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)82 дБ
CMRR(Typ)110 дБ
GBW(Typ)2 МГц
Input Bias Current(Max)4 pA
Iq per channel(Max)3.5 мА
Iq per channel(Typ)2.5 мА
Количество каналов2
Offset Drift(Typ)0.5 uV/C
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Output Current(Typ)40 мА
Package GroupPDIP
Rail-to-RailOut
Slew Rate(Typ)2 V/us
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.5 мВ
  • Feedback Plots Define Op Amp AC Performance
    PDF, 89 Кб, Файл опубликован: 27 сен 2000
    Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits.
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2111AM
