Datasheet Texas Instruments OPA2234UA — Даташит
СерияOPA2234
МодельOPA2234UA
Маломощные прецизионные операционные усилители с однополярным питанием 8-SOIC от -40 до 85
OPA234, 2234, 4234: Low Power, Precision Single-Supply Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 10 апр 2008
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY757575
CarrierTUBETUBETUBE
МаркировкаA2234UOPA
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)86 дБ
CMRR(Typ)106 дБ
GBW(Typ)0.35 МГц
Input Bias Current(Max)30000 pA
Iq per channel(Max)0.3 мА
Iq per channel(Typ)0.25 мА
Количество каналов2
Offset Drift(Typ)0.5 uV/C
Output Current(Typ)11 мА
Rail-to-RailIn to V-,Out
Slew Rate(Typ)0.2 V/us
Vn at 1kHz(Typ)25 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.1 мВ
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2234UA
