Datasheet Texas Instruments OPA2674I-14DG4 — Даташит
СерияOPA2674
МодельOPA2674I-14DG4
Двойной широкополосный операционный усилитель с высоким выходным током и ограничением тока 14-SOIC от -40 до 85
Dual Wideband High Output Current Operational Amplifier with Current Limit datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 28 авг 2008
Pin14
Package TypeD
Package QTY50
МаркировкаOPA2674
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic72 dBc
3rd Harmonic81 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Current FB
BW @ Acl250 МГц
CMRR(Min)51 дБ
CMRR(Typ)55 дБ
GBW(Typ)250 МГц
Input Bias Current(Max)25000000 pA
Iq per channel(Max)9.3 мА
Iq per channel(Typ)9 мА
Количество каналов2
Offset Drift(Typ)4 uV/C
Output Current(Typ)500 мА
Rail-to-RailNo
Slew Rate(Typ)2000 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5.75 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2 нВ/rtГц
Vn at Flatband(Typ)2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4.5 мВ
  • Evaluation Modules & Boards: THS3120EVM
    THS3120 Evaluation Module
  • Evaluation Modules & Boards: THS3111EVM
    THS3111 Evaluation Module
  • Evaluation Modules & Boards: DEM-OPA-SO-2D
    DEM-OPA-SO-2D
  • Evaluation Modules & Boards: THS3110EVM
    THS3110 Evaluation Module
  • Evaluation Modules & Boards: THS3121EVM
    THS3121 Evaluation Module
  • Evaluation Modules & Boards: DEM-OPA268XN
    DEM-OPA268xN: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • Current Feedback Amplifiers: Review, Stability Analysis, and Applications
    PDF, 53 Кб, Файл опубликован: 20 ноя 2000
    The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Op Amp Performance Analysis
OPA2674I14DG4, OPA2674I 14DG4
На английском языке: Datasheet Texas Instruments OPA2674I-14DG4
