Datasheet Texas Instruments TL022CP — Даташит
Серия | TL022 |
Модель | TL022CP |
Двойной маломощный операционный усилитель общего назначения 8-PDIP 0–70
Dual Low-Power Operational Amplifiers datasheet
PDF, 680 Кб, Файл опубликован: 1 сен 1990
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | TL022CP |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 60 дБ |
CMRR(Typ) | 72 дБ |
GBW(Typ) | 0.5 МГц |
Input Bias Current(Max) | 100000 pA |
Iq per channel(Max) | 0.125 мА |
Iq per channel(Typ) | 0.065 мА |
Количество каналов | 2 |
Рабочий диапазон температур | от 0 до 70 C |
Output Current(Typ) | 6 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 0.5 V/us |
Total Supply Voltage(Max) | 30 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 50 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 5 мВ |
Бессвинцовая технология (Pb Free) | Да |
- Understanding Operational Amplifier SpecificationsPDF, 273 Кб, Файл опубликован: 13 июл 1998
Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen - Handbook of Operational Amplifier Applications (Rev. B)PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
Серия: TL022 (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
