Datasheet Texas Instruments OPA2725AIDGKT — Даташит
Серия | OPA2725 |
Модель | OPA2725AIDGKT |
Двойной высокоскоростной малошумящий 12-вольтовый КМОП-операционный усилитель 8-VSSOP от -40 до 125
OPA725 and OPA726 Series: Very Low-Noise, High-Speed, 12V CMOS Op Amp datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 8 янв 2004
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | BGM |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 88 дБ |
CMRR(Typ) | 94 дБ |
GBW(Typ) | 20 МГц |
Input Bias Current(Max) | 200 pA |
Iq per channel(Max) | 5.5 мА |
Iq per channel(Typ) | 4.3 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 4 uV/C |
Output Current(Typ) | 40 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 30 V/us |
Total Supply Voltage(Max) | 12 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 10 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- OPA725, OPA2725, OPA726, OPA2726 EMI Immunity Performance (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 2 ноя 2012
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2725 (7)
- OPA2725AID OPA2725AIDG4 OPA2725AIDGKR OPA2725AIDGKT OPA2725AIDGKTG4 OPA2725AIDR OPA2725AIDRG4
