Datasheet Texas Instruments LM3900N — Даташит
СерияLM3900
МодельLM3900N
Счетверенный операционный усилитель 14-PDIP от 0 до 70
Quadruple Operational Amplifiers datasheet
PDF, 644 Кб, Файл опубликован: 1 сен 1990
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаLM3900N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
GBW(Typ)2.5 МГц
Input Bias Current(Max)200000 pA
Iq per channel(Max)2.5 мА
Iq per channel(Typ)1.55 мА
Количество каналов4
Output Current(Typ)10 мА
Package GroupPDIP
Rail-to-RailNo
Slew Rate(Typ)20 V/us
Total Supply Voltage(Max)32 +5V=5, +/-5V=10
Total Supply Voltage(Min)4.5 +5V=5, +/-5V=10
  • The LM3900 A New Current-Differencing Quad of Plus or Minus Input Amplifiers
    PDF, 682 Кб, Файл опубликован: 2 май 2004
  • True RMS Detector
    PDF, 88 Кб, Файл опубликован: 1 окт 2002
  • AN-20 An Applications Guide for Op Amps (Rev. C)
    PDF, 727 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application note is a guide for Op Amps. The circuits discussed herein are illustrative of the versatilityof the integrated operational amplifier and provide a guide to a number of useful applications. Thecautions noted in each section will show the more common pitfalls encountered in amplifier usage.
  • AN-24 A Simplified Test Set for Op Amp Characterization
    PDF, 1.2 Мб, Файл опубликован: 10 май 2004
    Application Note 24 A Simplified Test Set for Op Amp Characterization
  • AN-29 IC Op Amp Beats FETs on Input Current (Rev. B)
    PDF, 965 Кб, Версия: B, Файл опубликован: 1 май 2013
    This application note describes a monolithic operational amplifier which has input error currents in theorder of 100 pA over a в€’55В°C to 125В°C temperature range. Instead of FETs, the circuit used bipolartransistors with current gains of 5000 so that offset voltage and drift are not degraded. A powerconsumption of 1 mW at low voltage is also featured.A number of novel circuits that make use
  • AN-32 FET Circuit Applications
    PDF, 254 Кб, Файл опубликован: 10 май 2004
  • AN-4 Monolithic Op Amp—The Universal Linear Component (Rev. B)
    PDF, 579 Кб, Версия: B, Файл опубликован: 1 май 2013
    Operational amplifiers are undoubtedly the easiest and best way of performing a wide range of linearfunctions from simple amplification to complex analog computation. The cost of monolithic amplifiers isnow less than $2.00, in large quantities, which makes it attractive to design them into circuits where theywould not otherwise be considered. Yet low cost is not the only attraction of monoli
  • AN-241 Working with High Impedance Op Amps
    PDF, 169 Кб, Файл опубликован: 3 май 2004
    Application Note 241 Working with High Impedance Op Amps
  • AN-31 Op Amp Circuit Collection (Rev. B)
    PDF, 2.3 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides basic circuits of the Texas Instruments op amp collection.
  • AB-24 Bench Testing LM3900 and LM359 Input Parameters
    PDF, 142 Кб, Файл опубликован: 10 май 2004
    Application Brief 24 Bench Testing LM3900 and LM359 Input Parameters
  • AN-446 A 150W IC Op Amp Simplifies Design of Power Circuits
    PDF, 782 Кб, Файл опубликован: 10 май 2004
    Application Note 446 A 150W IC Op Amp Simplifies Design of Power Circuits
  • Building an Op Amp With Bipolar Transistors, A Historical Application Note (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 19 сен 2016
    It is well known that the voltage noise of an operational amplifier can be decreased by increasing the emitter currentof the input stage. The signal-to-noise ratio will be improved by the increase of bias, until the base current noise begins to dominate.
  • General Purpose Power Supply
    PDF, 94 Кб, Файл опубликован: 3 окт 2002
  • Precise Tri-Wave Generation
    PDF, 80 Кб, Файл опубликован: 2 окт 2002
  • AN-A The Monolithic Operational Amplifier: A Tutorial Study
    PDF, 379 Кб, Файл опубликован: 11 май 2004
  • AN-46 The Phase Locked Loop IC as a Communication System Building Block
    PDF, 314 Кб, Файл опубликован: 14 май 2004
  • Low Drift Amplifiers
    PDF, 71 Кб, Файл опубликован: 2 окт 2002
  • Predicting Op Amp Slew Rate Limited Response
    PDF, 139 Кб, Файл опубликован: 7 окт 2002
  • AN-260 A 20-Bit (1 ppm) Linear Slope-Integrating A/D Converter (Rev. B)
    PDF, 502 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses how combining an “inferior”, 20 year old A/D conversion technique with amicroprocessor, a developmental A/D converter achieves 1 part-per-million (20-bit) linearity.
  • Applying a New Precision Op Amp
    PDF, 421 Кб, Файл опубликован: 4 окт 2004
  • AN-30 Log Converters (Rev. B)
    PDF, 370 Кб, Версия: B, Файл опубликован: 1 май 2013
    One of the most predictable non-linear elements commonly available is the bipolar transistor. Therelationship between collector current and emitter base voltage is precisely logarithmic from currentsbelow one picoamp to currents above one milliamp. Using a matched pair of transistors and integratedcircuit operational amplifiers it is relatively easy to construct a linear to logarithmic conv
  • AN-278 Designing with a New Super Fast Dual Norton Amplifier (Rev. B)
    PDF, 867 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application note provides new design ideas and discusses the positive impact of designing with theDual Norton amplifier.
  • AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)
    PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
    Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n
  • Super Matched Bipolar Transistor Pair Sets New Standards for Drift and Noise (Rev. B)
    PDF, 966 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses how a super matched bipolar transistor pair sets new standards for driftand noise.
  • AN-480 A 40 MHz Programmable Video Op Amp
    PDF, 218 Кб, Файл опубликован: 11 май 2004
  • Audio Applications of Linear Integrated Circuits
    PDF, 272 Кб, Файл опубликован: 2 май 2004
  • Get Fast Stable Response From Improved Unity-Gain Followers
    PDF, 107 Кб, Файл опубликован: 2 окт 2002
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • AN-263 Sine Wave Generation Techniques (Rev. C)
    PDF, 747 Кб, Версия: C, Файл опубликован: 22 апр 2013
    This application note describes the sine wave generation techniques to control frequency amplitude anddistortion levels.
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • Get More Power Out of Dual or Quad Op-Amps
    PDF, 91 Кб, Файл опубликован: 2 окт 2002
Серия: LM3900 (5)
На английском языке: Datasheet Texas Instruments LM3900N
