Datasheet Texas Instruments OPA3695IDBQ — Даташит
СерияOPA3695
МодельOPA3695IDBQ
Сверхширокополосный операционный усилитель с токовой обратной связью и отключением 16-SSOP от -40 до 85
Triple, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 2 сен 2008
Pin16
Package TypeDBQ
Industry STD TermSSOP
Package QTY75
МаркировкаOP3695
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
2nd Harmonic65 dBc
3rd Harmonic86 dBc
@ MHz10
Acl, min spec gain2 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Current FB
BW @ Acl1000 МГц
CMRR(Min)51 дБ
CMRR(Typ)56 дБ
GBW(Typ)1000 МГц
Input Bias Current(Max)30000000 pA
Iq per channel(Max)13.3 мА
Iq per channel(Typ)12.9 мА
Количество каналов3
Offset Drift(Typ)15 uV/C
Output Current(Typ)120 мА
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)2400 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)3.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3.5 мВ
  • Evaluation Modules & Boards: OPA3695EVM
    OPA3695EVM Evaluation Module
  • Evaluation Modules & Boards: DEM-OPA-SSOP-3D
    DEM-OPA-SSOP-3D
  • Evaluation Modules & Boards: DEM-OPA-SSOP-3C
    DEM-OPA-SSOP-3C Evaluation Tools
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA3695 (2)
На английском языке: Datasheet Texas Instruments OPA3695IDBQ
