Datasheet Texas Instruments TLV2464CNE4 — Даташит
СерияTLV2464
МодельTLV2464CNE4
Четырехканальный операционный усилитель ввода/вывода малой мощности 14-PDIP от 0 до 70
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаTLV2464CN
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)71 дБ
CMRR(Typ)85 дБ
GBW(Typ)6.4 МГц
Input Bias Current(Max)14000 pA
Iq per channel(Max)0.65 мА
Iq per channel(Typ)0.55 мА
Количество каналов4
Offset Drift(Typ)2 uV/C
Рабочий диапазон температурот -40 до 125,0 до 70 C
Output Current(Typ)80 мА
Package GroupPDIP
Rail-to-RailIn,Out
Slew Rate(Typ)1.6 V/us
Total Supply Voltage(Max)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)11 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Pressure Transducer to ADC Application
    PDF, 78 Кб, Файл опубликован: 4 окт 2002
    A range of bridge-type transducers can measure numerous process variables. This report describes a pressure transducer and a bridge transducer to measure strain in mechanical elements. It gives an example circuit from which to implement other applications.
  • Using the TLV246x as a Multiplexer with Gain in a Data Acquisition System
    PDF, 62 Кб, Файл опубликован: 14 дек 1998
    Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters.
  • TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
На английском языке: Datasheet Texas Instruments TLV2464CNE4
