Datasheet Texas Instruments OPA404AG — Даташит
СерияOPA404
МодельOPA404AG
Четырехскоростной прецизионный операционный усилитель Difet® 14-CDIP SB
Quad High Speed Precision Difet® Operational Amplifier datasheet
PDF, 753 Кб, Файл опубликован: 27 сен 2000
Pin14
Package TypeJD
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Package QTY1
МаркировкаOPA404AG
Width (мм)7.49
Length (мм)18.55
Thickness (мм)2.8
Pitch (мм)2.54
Max Height (мм)4.45
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)88 дБ
CMRR(Typ)100 дБ
GBW(Typ)6.4 МГц
Input Bias Current(Max)4 pA
Iq per channel(Max)10 мА
Iq per channel(Typ)9 мА
Количество каналов4
Offset Drift(Typ)3 uV/C
Output Current(Typ)27 мА
Package GroupPDIP,SOIC
Package Size: mm2:W x LSee datasheet (PDIP),16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Rail-to-RailOut
Slew Rate(Typ)35 V/us
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)15 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.75 мВ
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA404AG
