Datasheet LT1991HMS - Linear Technology Даташит ИС, GAIN SELECTABLE усилитель, 110 кГц, MSOP-10 — Даташит
Наименование модели: LT1991HMS
![]() 34 предложений от 19 поставщиков Микросхема Буферный усилитель, LINEAR TECHNOLOGY LT1991HMS#PBF Programmable/Variable Amplifier, 1Channels, 1 Amplifier, 560kHz, -40℃, 125℃, 2.7V to ± 18V | |||
LT1991HMS#PBF Analog Devices | 124 ₽ | ||
LT1991HMS Analog Devices | от 587 ₽ | ||
LT1991HMS#PBF Analog Devices | от 607 ₽ | ||
LT1991HMS#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, GAIN SELECTABLE усилитель, 110 кГц, MSOP-10
LT1991 Precision, 100µA Gain Selectable Amplifier FEATURES
n n
DESCRIPTION
The LT®1991 combines a precision operational amplifier with eight precision resistors to form a one-chip solution for accurately amplifying voltages.
Gains from 13 to 14 with a gain accuracy of 0.04% can be achieved using no external components. The device is particularly well suited for use as a difference amplifier, where the excellent resistor matching results in a common mode rejection ratio of greater than 75dB. The amplifier features a 50V maximum input offset voltage and a gain bandwidth product of 560kHz. The device operates from any supply voltage from 2.7V to 36V and draws only 100A supply current on a 5V supply. The output swings to within 40mV of either supply rail. The resistors have excellent matching, 0.04% over temperature for the 450k resistors. The matching temperature coefficent is guaranteed less than 3ppm/°C. The resistors are extremely linear with voltage, resulting in a gain nonlinearity
- Количество усилителей: 1
- Полоса частот: 560 кГц
- Rail To Rail: Rail Rail Outputs
- Количество каналов: 1
- Диапазон напряжения питания: 2.7 В ... ± 18 В
- Тип корпуса: MSOP
- Количество выводов: 10
Дополнительные аксессуары:
- Linear Technology - LTC2634IMSE-HZ12#PBF.
- Linear Technology - LTC2634IUD-HMI12#PBF.
- Linear Technology - LTC2634IUD-HMX12#PBF.
- Linear Technology - LTC2634IUD-LMI12#PBF.
- Linear Technology - LTC2634IUD-LMX12#PBF.
