Datasheet LTC6912CGN-1 - Linear Technology Даташит ИС, SM, операционный усилитель PROG GAIN, сдвоенный — Даташит
Наименование модели: LTC6912CGN-1
![]() 31 предложений от 20 поставщиков Микросхема Буферный усилитель, LINEAR TECHNOLOGY LTC6912CGN-1#PBF Programmable/Variable Amplifier, 1Channels, 2 Amplifier, 50MHz, -40℃, 85℃, 2.7V to 10.5V | |||
LTC6912CGN-1#TRPBF Analog Devices | 90 ₽ | ||
LTC6912CGN-1 Linear Technology | 188 ₽ | ||
LTC6912CGN-1#TRPBF Linear Technology | по запросу | ||
LTC6912CGN-1#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, SM, операционный усилитель PROG GAIN, сдвоенный
LTC6912 Dual Programmable Gain Amplifiers with Serial Digital Interface DESCRIPTIO
The LTC®6912 is a family of dual channel, low noise, digitally programmable gain amplifiers (PGA) that are easy to use and occupy very little PC board space.
The gains for both channels are independently programmable using a 3-wire SPI interface to select voltage gains of 0, 1, 2, 5, 10, 20, 50, and 100V/V (LTC6912-1 ); and 0, 1, 2, 4, 8, 16, 32, and 64V/V (LTC6912-2). All gains are inverting. The LTC6912 family consists of 2 matched amplifiers with rail-to-rail outputs. When operated with unity gain, they will also process rail-to-rail input signals. A half-supply reference generated internally at the AGND pin supports single power supply applications. Operating from single or split supplies from 2.7V to 10.5V total, the LTC6912-X family is offered in tiny SSOP and DFN-12 Packages.
, LTC and LT are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their res
- Количество усилителей: 2
- Полоса частот: 50 МГц
- Rail To Rail: Rail-Rail I/O
- Количество каналов: 1
- Диапазон напряжения питания: 2.7 В ... 10.5 В
- Тип корпуса: SSOP
- Количество выводов: 16
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип усилителя: Programmable Gain
- Семейство: 6912
- Добротность: 33 МГц
- Коэффициент усиления максимальный: 100 дБ
- Напряжение смещения входа максимальное: 3.5 мВ
- Скорость нарастания: 12
- Напряжение питания (+) номинальное: 5.5 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE931-02
- STANNOL - 631954
LTC6912CGN1, LTC6912CGN 1
