Datasheet LF398M - National Semiconductor Даташит Усилитель, моно, выборки-хранения, 14SOIC — Даташит
National Semiconductor LF398M
Наименование модели: LF398M
53 предложений от 22 поставщиков
LF398M/NOPB
177 ₽
LF398M/NOPB
от 244 ₽
Эиком
LF398M
от 278 ₽
LF398M
Описание: Усилитель, моно, выборки-хранения, 14SOIC
data sheetСкачать Data Sheet
LF198/LF298/LF398, LF198A/LF398A Monolithic Sample-and-Hold Circuits
July 2000
General Description
The LF198/LF298/LF398 are monolithic sample-and-hold circuits which utilize BI-FET technology to obtain ultra-high dc accuracy with fast acquisition of signal and low droop rate.
Operating as a unity gain follower, dc gain accuracy is 0.002% typical and acquisition time is as low as 6 µs to 0.01%. A bipolar input stage is used to achieve low offset voltage and wide bandwidth. Input offset adjust is accomplished with a single pin, and does not degrade input offset drift. The wide bandwidth allows the LF198 to be included inside the feedback loop of 1 MHz op amps without having stability problems. Input impedance of 1010 allows high source impedances to be used without degrading accuracy. P-channel junction FET's are combined with bipolar devices in the output amplifier to give droop rates as low as 5 mV/min with a 1 µF
  • Количество усилителей: 1
  • Полоса частот: 1 МГц
  • Acquisition Time: 20 мкс
  • Напряжение смещения входа: 2 мВ
  • Диапазон напряжения питания: ± 5 В ... ± 18 В
  • Тип корпуса: SOIC
  • Количество выводов: 14
  • Рабочий диапазон температрур: 0°C ... +70°C
  • SVHC: No SVHC (15-Dec-2010)
  • Семейство: 398
На английском языке: Datasheet LF398M - National Semiconductor AMP, MONO, SAMPLE & HOLD, 14SOIC
