Datasheet LF398AN/NOPB - National Semiconductor Даташит ИС, выборки-хранения усилитель, 1 МГц, 20 uS, DIP-8 — Даташит
Наименование модели: LF398AN/NOPB
Купить LF398AN/NOPB на РадиоЛоцман.Цены — от 36 до 450 ₽31 предложений от 20 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
| LF398AN/NOPB Texas Instruments | 134 ₽ | ||
| LF398AN/NOPB Texas Instruments | от 402 ₽ | ||
| LF398AN/NOPB Texas Instruments | 426 ₽ | ||
| LF398AN/NOPB Texas Instruments | по запросу | ||
Описание: ИС, выборки-хранения усилитель, 1 МГц, 20 uS, DIP-8
LF198/LF298/LF398, LF198A/LF398A Monolithic Sample-and-Hold Circuits
July 2000
General Description
The LF198/LF298/LF398 are monolithic sample-and-hold circuits which utilize BI-FET technology to obtain ultra-high dc accuracy with fast acquisition of signal and low droop rate.
Operating as a unity gain follower, dc gain accuracy is 0.002% typical and acquisition time is as low as 6 µs to 0.01%. A bipolar input stage is used to achieve low offset voltage and wide bandwidth. Input offset adjust is accomplished with a single pin, and does not degrade input offset drift. The wide bandwidth allows the LF198 to be included inside the feedback loop of 1 MHz op amps without having stability problems. Input impedance of 1010 allows high source impedances to be used without degrading accuracy. P-channel junction FET's are combined with bipolar devices in the output amplifier to give droop rates as low as 5 mV/min with a 1 µF
- Время выборки: 20 мкс
- Диапазон напряжения питания: ± 5 В ... ± 18 В
- Количество выводов: 8
- Количество усилителей: 1
- Напряжение смещения входа: 2 мВ
- Полоса частот: 1 МГц
- Тип корпуса: DIP
- RoHS: да
