Datasheet MAX9654AUB+ - Maxim Даташит FILTER усилитель, 3.3 В, HD/SD, 3CH, 10UMAX — Даташит
Maxim MAX9654AUB+
Наименование модели: MAX9654AUB+
Микросхема Видеоусилитель, * 9.5mA/Channel Supply Current * Selectable Lowpass Filter for High-Definition or Standard-Definition Video Signals (MAX9654) * 8.5MHz Standard-Definition Passband...
MAX9654AUB+T
Maxim
93 ₽
ЗУМ-СМД
MAX9654AUB+T
Maxim
MAX9654AUB+
MAX9654AUB+T
Maxim
Производитель: Maxim
Описание: FILTER усилитель, 3.3 В, HD/SD, 3CH, 10UMAX
data sheetСкачать Data Sheet
19-4236; Rev 0; 8/08
EVALUATION KIT AVAILABLE
3.3V, HD/SD Triple-Channel Filter Amplifiers with Shutdown
General Description
The MAX9652/MAX9653/MAX9654 are 3.3V, triplechannel, high-definition (HD) video-filter amplifiers.
Specially designed for YPbPr component video signals, these devices are ideal for a wide range of set-top box and portable applications. The inputs to the MAX9652/ MAX9653/MAX9654 are AC-coupled. YIN has a synctip clamp while PBIN and PRIN have keyed clamps. The output buffer has gain of 2V/V and drives a standard back-terminated 75 video load. The passband of the MAX9654 is logic selectable between standard definition (SD) and high definition. The MAX9652/MAX9653 have a fixed passband for HD video. The MAX9654 SD lowpass filter has ±1dB passband out to 8.5MHz and 57dB attenuation at 27MHz. The MAX9652/MAX9653/MAX9654 HD lowpass filter have ±1dB passband out to 42MHz and 50dB attenuation at 109MHz. The devices consume only 9.5mA per channel and operate from a 3.3V
Данные для моделированияДанные для моделирования
  • Диапазон напряжения питания: 3.135 В ... 3.465 В
  • Количество усилителей: 3
  • Тип выхода: Rail ... Rail
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Количество выводов: 10
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: UMAX
  • Тип усилителя: Filter
  • Семейство: 9654
  • Способ монтажа: SMD
На английском языке: Datasheet MAX9654AUB+ - Maxim FILTER AMP, 3.3 V, HD/SD, 3CH, 10UMAX
