Datasheet MJ10016 - NTE Electronics Даташит Транзистор — Даташит
Наименование модели: MJ10016
Производитель: NTE Electronics
Описание: Транзистор
MJ10015 & MJ10016 T-NPN, Si, Darlington w/Base-Emitter Speedup Diode
Description: The MJ10015 and MJ10016 are Darlington transistors in a TO3 type package designed for high- voltage, high-speed, power switching in inductive circuits where fall time is critical.
They are particularly suited for line operated switch-mode applications. Applications: D Continuous Collector Current (IC = 50A) D Switching Regulators D Inverters D Solenoid and Relay Drivers D Motor Controls Absolute Maximum Ratings: Collector-Emitter Voltage, VCEV MJ10015 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 600V MJ10016 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 700V Collector-Emitter Voltage, VCEO(SUS) MJ10015 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
- Полярность транзистора: NPN
- Collector Emitter Voltage V(br)ceo: 500 В
- Power Dissipation Pd: 250 Вт
- DC Collector Current: 50 А
- Корпус транзистора: TO-3
- Количество выводов: 2
- SVHC: No SVHC (15-Dec-2010)
- Collector Emitter Voltage Vces: 5 В
- Current Ic Continuous a Max: 50 А
- DC Current Gain: 25
- DC Current Gain Min: 10
- Тип корпуса: TO-3
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Fischer Elektronik - AKK 191
- Multicomp - MK3301/S
