Datasheet ATF-501P8-BLK - Avago Technologies Даташит Транзистор, GAAS, HI-LIN — Даташит
Avago Technologies ATF-501P8-BLK
Наименование модели: ATF-501P8-BLK
транзистор характеристики, Trans JFET 7V 1A 8Pin LPCC Bag
ATF-501P8-BLK
Broadcom
272 ₽
ATF-501P8-BLK
Avago Technologies
ATF-501P8-BLK
Avago Technologies
ATF-501P8-BLK
Broadcom
Производитель: Avago Technologies
Описание: Транзистор, GAAS, HI-LIN
data sheetСкачать Data Sheet
ATF-501P8
High Linearity Enhancement Mode[1] Pseudomorphic HEMT in 2x2 mm2 LPCC[3] Package
Data Sheet
Description
Avago Technologies's ATF-501P8 is a single-voltage high linearity, low noise E-pHEMT housed in an 8-lead JEDECstandard leadless plastic chip carrier (LPCC[3]) package.
The device is ideal as a medium-power amplifier. Its operating frequency range is from 400 MHz to 3.9 GHz. The thermally efficient package measures only 2mm x 2mm x 0.75mm. Its backside metalization provides excellent thermal dissipation as well as visual evidence of solder reflow. The device has a Point MTTF of over 300 years at a mounting temperature of +85єC. All devices are 100% RF & DC tested.
  • Continuous Drain Current Id: 1 А
  • Drain Source Voltage Vds: 7 В
  • Voltage Vgs Max: 800 мВ
  • Корпус транзистора: LPCC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Cont Current Id @ 25В°C: 1 А
  • Current Id Max: 1 А
  • Частота единичного усиления минимальная: 400 МГц
  • Частота единичного усиления типовая: 2 ГГц
  • Количество транзисторов: 1
  • Тип корпуса: LPCC
  • Pin Configuration: S(1), G(2), D(7), N/C(3+5+6+8)
  • Power Dissipation Pd: 3.5 Вт
  • SMD Marking: 0Px
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 330 мВ
  • Voltage Vds Typ: 4.5 В
ATF501P8BLK, ATF 501P8 BLK
На английском языке: Datasheet ATF-501P8-BLK - Avago Technologies TRANSISTOR, GAAS, HI-LIN
