Datasheet FDC6302P - Fairchild Даташит Полевой транзистор P CH сдвоенный 25 В 0.12 А SSOT6 — Даташит
Наименование модели: FDC6302P
![]() 19 предложений от 17 поставщиков Mosfet Array 25V 120mA 700mW Surface Mount SuperSOTTM-6 | |||
FDC6302P ON Semiconductor | 23 ₽ | ||
FDC6302P Fairchild | 66 ₽ | ||
FDC6302P ON Semiconductor | 99 ₽ | ||
FDC6302P Fairchild | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор P CH сдвоенный 25 В 0.12 А SSOT6
October 1997
FDC6302P Digital FET, Dual P-Channel
General Description
These Dual P-Channel logic level enhancement mode field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors in load switchimg applications. Since bias resistors are not required this one P-Channel FET can replace several digital transistors with different bias resistors like the IMBxA series.
Features
- Полярность транзистора: P Channel
- Continuous Drain Current Id: -200 мА
- Drain Source Voltage Vds: -25 В
- On Resistance Rds(on): 10 Ом
- Rds(on) Test Voltage Vgs: -4.5 В
- Threshold Voltage Vgs Typ: -1 В
- Рассеиваемая мощность: 900 мВт
- Рабочий диапазон температрур: -55°C ... +150°C
- Корпус транзистора: SSOT
- Количество выводов: 6
- SVHC: No SVHC (19-Dec-2011)
- Current Id Max: -120 мА
- Тип корпуса: SSOT
- Способ монтажа: SMD
- Voltage Vds Typ: -25 В
- Voltage Vgs Max: -1 В
- Voltage Vgs Rds on Measurement: -4.5 В
