Datasheet FDC6321C - Fairchild Даташит Полевой транзистор, сдвоенный, NP, SUPERSOT-6 — Даташит
Fairchild FDC6321C
Наименование модели: FDC6321C
54 предложений от 25 поставщиков
Двойной МОП-транзистор, N и P Дополнение, 25 В, 460 мА, 0.33 Ом, SuperSOT, Surface Mount
FDC6321C
от 20 ₽
Элитан
FDC6321C
22 ₽
Триема
FDC6321C
32 ₽
FDC6321C_NL
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, NP, SUPERSOT-6
data sheetСкачать Data Sheet
April 1999
FDC6321C Dual N & P Channel , Digital FET
General Description
These dual N & P Channel logic level enhancement mode field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors in load switching applications. Since bias resistors are not required this dual digital FET can replace several digital transistors with different bias resistors.
Features
  • Полярность транзистора: N and P Channel
  • Continuous Drain Current Id: 460 мА
  • Drain Source Voltage Vds: 25 В
  • On Resistance Rds(on): 1.1 Ом
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Voltage Vgs Max: 800 мВ
  • Корпус транзистора: SuperSOT
  • Количество выводов: 6
  • SVHC: No SVHC (15-Dec-2010)
  • Cont Current Id N Channel 2: 2.7 А
  • Cont Current Id P Channel: 1.6 А
  • Current Id Max: 680 мА
  • Current Temperature: 25°C
  • Количество транзисторов: 2
  • On State Resistance N Channel Max: 680 МОм
  • On State Resistance P Channel Max: 450 МОм
  • Тип корпуса: SuperSOT-6
  • Power Dissipation Pd: 900 мВт
  • Pulse Current Idm: 1.5 А
  • SMD Marking: FDC6321C
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 800 мВ
  • Uni / Bi Directional Polarity: NP
  • Voltage Vds: 25 В
  • Voltage Vds Typ: 25 В
  • Voltage Vgs Rds on Measurement: 4.5 В
  • Voltage Vgs th Max: 1.5 В
Дополнительные аксессуары:
  • LICEFA - V11-7-6-10
  • LICEFA - V11-7
  • Panasonic - EYGA121807A
На английском языке: Datasheet FDC6321C - Fairchild MOSFET, DUAL, NP, SUPERSOT-6
