Datasheet FDS6680AS - Fairchild Даташит Полевой транзистор, N, SMD, SO-8 — Даташит
Наименование модели: FDS6680AS
Производитель: Fairchild
Описание: Полевой транзистор, N, SMD, SO-8
FDS6680AS 30V N-Channel PowerTrench® SyncFETTM
May 2008
General Description
The FDS6680AS is designed to replace a single SO-8 MOSFET and Schottky diode in synchronous DC:DC power supplies.
This 30V MOSFET is designed to maximize power conversion efficiency, providing a low RDS(ON) and low gate charge. The FDS6680AS includes an integrated Schottky diode using Fairchild's monolithic SyncFET technology. The performance of the FDS6680AS as the low-side switch in a synchronous rectifier is indistinguishable from the performance of the FDS6680 in parallel with a Schottky diode.
- Continuous Drain Current Id: 11.5 А
- Drain Source Voltage Vds: 30 В
- On Resistance Rds(on): 10 МОм
- Threshold Voltage Vgs Typ: 1.5 В
- Рассеиваемая мощность: 2.5 мВт
- Рабочий диапазон температрур: -55°C ... +150°C
- Корпус транзистора: SOIC
- Количество выводов: 8
- SVHC: No SVHC (19-Dec-2011)
- Current Id Max: 11.5 А
- Количество транзисторов: 1
- Тип корпуса: SOIC
- Pulse Current Idm: 50 А
- Способ монтажа: SMD
- Voltage Vds Typ: 30 В
- Voltage Vgs Max: 20 В
- Voltage Vgs Rds on Measurement: 10 В
