HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet HUF75639P3 - Fairchild Даташит Полевой транзистор, N CH, 100 В, 56 А, TO-220AB — Даташит
Fairchild HUF75639P3
Наименование модели: HUF75639P3
33 предложений от 20 поставщиков
Силовой МОП-транзистор, N Канал, 100 В, 56 А, 0.021 Ом, TO-220AB, Through Hole
HUF75639P3 (ST-STP60NF10)
24 ₽
HUF75639P3_F102
Fairchild
94 ₽
HUF75639P3
115 ₽
ТаймЧипс
HUF75639P3NL
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, N CH, 100 В, 56 А, TO-220AB
data sheetСкачать Data Sheet
HUF75639G3, HUF75639P3, HUF75639S3S, HUF75639S3
Data Sheet December 2001
56A, 100V, 0.025 Ohm, N-Channel UltraFET Power MOSFETs
These N-Channel power MOSFETs are manufactured using the innovative UltraFET® process.
This advanced process technology achieves the lowest possible on-resistance per silicon area, resulting in outstanding performance. This device is capable of withstanding high energy in the avalanche mode and the diode exhibits very low reverse recovery time and stored charge. It was designed for use in applications where power efficiency is important, such as switching regulators, switching converters, motor drivers, relay drivers, lowvoltage bus switches, and power management in portable and battery-operated products. Formerly developmental type TA75639.
Features
  • Drain Source Voltage Vds: 100 В
  • On Resistance Rds(on): 21 МОм
  • Voltage Vgs Max: 20 В
  • Рабочий диапазон температрур: -55°C ... +175°C
  • Корпус транзистора: TO-220AB
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 56 А
  • Power Dissipation Pd: 200 Вт
Дополнительные аксессуары:
  • Fischer Elektronik - FK 245 MI 247 V
  • MULTICORE (SOLDER) - 1399095-M
На английском языке: Datasheet HUF75639P3 - Fairchild MOSFET, N CH, 100 V, 56 A, TO-220AB
