Datasheet RFD16N05LSM - Fairchild Даташит Полевой транзистор, N, LOGIC, D-PAK — Даташит
Fairchild RFD16N05LSM
Наименование модели: RFD16N05LSM
44 предложений от 24 поставщиков
MOSFET N-CH 50V 16A TO-252AA. N-Channel 50V 16A (Tc) 60W (Tc) Surface Mount TO-252AA. Transistors - FETs, MOSFETs - Single
RFD16N05LSM9A
от 12 ₽
RFD16N05LSM9A
от 129 ₽
ТаймЧипс
RFD16N05LSM9A
Fairchild
727GS
RFD16N05LSM9A
Производитель: Fairchild
Описание: Полевой транзистор, N, LOGIC, D-PAK
data sheetСкачать Data Sheet
RFD16N05L, RFD16N05LSM
Data Sheet December 2003
16A, 50V, 0.047 Ohm, Logic Level, N-Channel Power MOSFETs
These are N-Channel logic level power MOSFETs manufactured using the MegaFET process.
This process, which uses feature sizes approaching those of LSI integrated circuits gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use with logic level (5V) driving sources in applications such as programmable controllers, automotive switching, switching regulators, switching converters, motor relay drivers and emitter switches for bipolar transistors. This performance is accomplished through a special gate oxide design which provides full rated conductance at gate biases in the 3V to 5V range, thereby facilitating true on-off power control directly from logic circuit supply voltages. Formerly developmental type TA09871.
Features
  • Continuous Drain Current Id: 16 А
  • Drain Source Voltage Vds: 50 В
  • On Resistance Rds(on): 47 МОм
  • Rds(on) Test Voltage Vgs: 5 В
  • Voltage Vgs Max: 2 В
  • Рабочий диапазон температрур: -55°C ... +175°C
  • Корпус транзистора: D-PAK
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Альтернативный тип корпуса: D-PAK
  • Current Id Max: 16 А
  • Current Temperature: 25°C
  • Количество транзисторов: 1
  • Тип корпуса: DPAK
  • Power Dissipation Pd: 60 Вт
  • Pulse Current Idm: 45 А
  • SMD Marking: RFD16N05LSM
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 2 В
  • Voltage Vds Typ: 50 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Max: 2 В
RoHS: Y-Ex
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 08 D PAK
  • Fischer Elektronik - FK 244 13 D PAK
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet RFD16N05LSM - Fairchild MOSFET, N, LOGIC, D-PAK
