Datasheet RFP12N10L - Fairchild Даташит Полевой транзистор, N, LOGIC, TO-220 — Даташит
Наименование модели: RFP12N10L
![]() 38 предложений от 20 поставщиков Силовой МОП-транзистор, N Канал, 100 В, 12 А, 0.2 Ом, TO-220AB, Through Hole | |||
RFP12N10L ON Semiconductor | 31 ₽ | ||
RFP12N10L ON Semiconductor | от 33 ₽ | ||
RFP12N10L ON Semiconductor | от 88 ₽ | ||
RFP12N10L/IPS Fairchild | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор, N, LOGIC, TO-220
RFP12N10L
Data Sheet April 2005
12A, 100V, 0.200 Ohm, Logic Level, N-Channel Power MOSFET
These are N-Channel enhancement mode silicon gate power field effect transistors specifically designed for use with logic level (5V) driving sources in applications such as programmable controllers, automotive switching and solenoid drivers.
This performance is accomplished through a special gate oxide design which provides full rated conduction at gate biases in the 3V to 5V range, thereby facilitating true on-off power control directly from logic circuit supply voltages. Formerly developmental type TA09526.
Features
- Continuous Drain Current Id: 12 А
- Drain Source Voltage Vds: 100 В
- On Resistance Rds(on): 200 МОм
- Rds(on) Test Voltage Vgs: 5 В
- Voltage Vgs Max: 2 В
- Рабочий диапазон температрур: -55°C ... +175°C
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 12 А
- Current Temperature: 25°C
- Расстояние между выводами: 2.54 мм
- Количество транзисторов: 1
- Тип корпуса: TO-220AB
- Power Dissipation Pd: 60 Вт
- Pulse Current Idm: 30 А
- SMD Marking: RFP12N10L
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 2 В
- Voltage Vds Typ: 100 В
- Voltage Vgs Rds on Measurement: 5 В
- Voltage Vgs th Max: 2 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
