Datasheet RFP50N06 - Fairchild Даташит Полевой транзистор, N, TO-220 — Даташит
Наименование модели: RFP50N06
![]() 53 предложений от 30 поставщиков MOSFET, N, TO-220; Transistor Type:MOSFET; Transistor Polarity:N; Voltage, Vds Typ:60V; Current, Id Cont:50A; Resistance, Rds On:0.022ohm; Voltage, Vgs Rds on Measurement:10V;... | |||
RFP50N06R4034 Texas Instruments | 138 ₽ | ||
RFP50N06TU Fairchild | по запросу | ||
RFP50N06R4719 Fairchild | по запросу | ||
RFP50N06R Fairchild | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор, N, TO-220
RFG50N06, RFP50N06, RF1S50N06SM
Data Sheet January 2002
50A, 60V, 0.022 Ohm, N-Channel Power MOSFETs
These N-Channel power MOSFETs are manufactured using the MegaFET process.
This process, which uses feature sizes approaching those of LSI integrated circuits gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers, and relay drivers. These transistors can be operated directly from integrated circuits. Formerly developmental type TA49018.
Features
- Continuous Drain Current Id: 50 А
- Drain Source Voltage Vds: 60 В
- On Resistance Rds(on): 22 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 50 А
- Current Temperature: 25°C
- Маркировка: RFP50N06
- Количество транзисторов: 1
- On State Resistance Max: 22 МОм
- Тип корпуса: TO-220AB
- Power Dissipation Pd: 131 Вт
- Pulse Current Idm: 120 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 60 В
- Voltage Vgs Rds on Measurement: 10 В
- Voltage Vgs th Max: 4 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
