Datasheet IRF230 - International Rectifier Даташит Полевой транзистор, N, TO-3 — Даташит
International Rectifier IRF230
Наименование модели: IRF230
20 предложений от 18 поставщиков
, Power Field-Effect Transistor, 9A I(D), 200V, 0.4ohm, 1-Element, N-Channel, Silicon, Metal-oxide Semiconductor FET, TO-204AA
TradeElectronics
IRF230R
Samsung
МосЧип
IRF230(TO3)
Samsung
727GS
IRF230
Hi-Tech Circuit Group
IRF230
Harris
Описание: Полевой транзистор, N, TO-3
data sheetСкачать Data Sheet
PD - 90334F
IRF230 REPETITIVE A ALANCHE AND dv/dt RATED V JANTX2N6758 HEXFET TRANSISTORS JANTXV2N6758 THRU-HOLE (TO-204AA/AE) [REF:MIL-PRF-19500/542] 200V, N-CHANNEL
Product Summary
Part Number IRF230 BVDSS 200V RDS(on) 0.40 ID 9.0A
The HEXFET technology is the key to International Rectifier's advanced line of power MOSFET transistors.
The efficient geometry and unique processing of this latest "State of the Art" design achieves: very low on-state resistance combined with high transconductance; superior reverse energy and diode recovery dv/dt capability. The HEXFET transistors also feature all of the well established advantages of MOSFETs such as voltage control, very fast switching, ease of paralleling and temperature stability of the electrical parameters. They are well suited for applications such as switching power supplies, motor controls, inverters, choppers, audio amplifiers and high energy pulse circuits.
  • Continuous Drain Current Id: 9 А
  • Drain Source Voltage Vds: 200 В
  • On Resistance Rds(on): 400 МОм
  • Voltage Vgs Max: 4 В
  • Корпус транзистора: TO-3
  • Количество выводов: 2
  • SVHC: No SVHC (15-Dec-2010)
  • Avalanche Single Pulse Energy Eas: 54mJ
  • Current Iar: 9 А
  • Current Id Max: 9 А
  • Current Temperature: 25°C
  • Fixing Centres: 30 мм
  • Температура перехода максимальная: 150°C
  • Температура перехода минимальная: -55°C
  • Расстояние между выводами: 11 мм
  • Количество транзисторов: 1
  • Тип корпуса: TO-3
  • Power Dissipation Pd: 75 Вт
  • Pulse Current Idm: 36 А
  • Repetitive Avalanche Energy Max: 7.5mJ
  • Threshold Voltage Vgs Typ: 4 В
  • Voltage Vds Typ: 200 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Max: 4 В
  • Вес: 0.01kg
Дополнительные аксессуары:
  • Fischer Elektronik - AKK 191
  • Fischer Elektronik - FK 201SA-3
  • Fischer Elektronik - SK 04/50 SA
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet IRF230 - International Rectifier MOSFET, N, TO-3
