Datasheet IRF7811AVPBF - International Rectifier Даташит Полевой транзистор, N, LOGIC, SO-8 — Даташит
International Rectifier IRF7811AVPBF
Наименование модели: IRF7811AVPBF
15 предложений от 15 поставщиков
Труба MOS, Trans MOSFET N-CH 30V 10.8A 8Pin SOIC Tube
IRF7811AVPBF
22 ₽
IRF7811AVPBF
38 ₽
Microfind
IRF7811AVPBF
Infineon
356 ₽
727GS
IRF7811AVPBF
Infineon
Описание: Полевой транзистор, N, LOGIC, SO-8
data sheetСкачать Data Sheet
PD-95265 IRF7811AVPbF IRF7811AVPbF
· · · · · N-Channel Application-Specific MOSFETs Ideal for CPU Core DC-DC Converters Low Conduction Losses Low Switching Losses Minimizes Parallel MOSFETs for high current applications · 100% RG Tested · Lead-Free Description This new device employs advanced HEXFET Power MOSFET technology to achieve an unprecedented balance of on-resistance and gate charge.
The reduced conduction and switching losses make it ideal for high efficiency DC-DC converters that power the latest generation of microprocessors. The IRF7811AV has been optimized for all parameters that are critical in synchronous buck converters including RDS(on), gate charge and Cdv/dt-induced turn-on immunity. The IRF7811AV offers an extremely low combination of Qsw & RDS(on) for reduced losses in both control and synchronous FET applications. The package is designed for vapor phase, infra-red, convection, or wave soldering techniques. Power dissipation of greater than 2W is possible in a typi
Данные для моделированияДанные для моделирования
  • Continuous Drain Current Id: 10.8 А
  • Drain Source Voltage Vds: 30 В
  • On Resistance Rds(on): 11 МОм
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Voltage Vgs Max: 3 В
  • Корпус транзистора: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 14 А
  • Current Temperature: 25°C
  • External Depth: 5.2 мм
  • Внешняя длина / высота: 1.75 мм
  • Внешняя ширина: 4.05 мм
  • Количество транзисторов: 1
  • Тип корпуса: SOIC
  • Pin Format: 1 с
  • Power Dissipation Pd: 2.5 Вт
  • Pulse Current Idm: 10.8 А
  • Расстояние между рядами выводов: 6.3 мм
  • SMD Marking: IRF7811AVPBF
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 3 В
  • Voltage Vds Typ: 30 В
  • Voltage Vgs Rds on Measurement: 4.5 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 5 SA
  • Fischer Elektronik - WLK 5
  • Roth Elektronik - RE932-01
На английском языке: Datasheet IRF7811AVPBF - International Rectifier MOSFET, N, LOGIC, SO-8
