Datasheet IRFIZ24NPBF - International Rectifier Даташит Полевой транзистор, N, FULLPAK — Даташит
Наименование модели: IRFIZ24NPBF
![]() 35 предложений от 15 поставщиков Силовой МОП-транзистор, N Канал, 55 В, 14 А, 0.07 Ом, TO-220FP, Through Hole | |||
IRFIZ24NPBF International Rectifier | 31 ₽ | ||
IRFIZ24NPBF Infineon | от 52 ₽ | ||
IRFIZ24NPBF Infineon | от 203 ₽ | ||
IRFIZ24NPBF International Rectifier | по запросу |
Описание: Полевой транзистор, N, FULLPAK
PD - 94808
IRFIZ24NPbF
Advanced Process Technology Isolated Package High Voltage Isolation = 2.5KVRMS Sink to Lead Creepage Dist.
= 4.8mm Fully Avalanche Rated Lead-Free Description
Fifth Generation HEXFETs from International Rectifier utilize advanced processing techniques to achieve extremely low on-resistance per silicon area. This benefit, combined with the fast switching speed and ruggedized device design that HEXFET Power MOSFETs are well known for, provides the designer with an extremely efficient and reliable device for use in a wide variety of applications. The TO-220 Fullpak eliminates the need for additional insulating hardware in commercial-industrial applications. The moulding compound used provides a high isolation capability and a low thermal resistance between the tab and external heatsink. This isolation is equivalent to using a 100 micron mica barrier with standard TO-220 product. The Fullpak is mounted to a heatsink using a single clip or by a single screw fixing.
- Continuous Drain Current Id: 14 А
- Drain Source Voltage Vds: 55 В
- On Resistance Rds(on): 70 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: TO-220FP
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 14 А
- Current Temperature: 25°C
- External Depth: 5.2 мм
- Внешняя длина / высота: 1.75 мм
- Внешняя ширина: 4.05 мм
- Тип корпуса: TO-220FP
- Power Dissipation Pd: 29 Вт
- Pulse Current Idm: 68 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 55 В
- Voltage Vgs Rds on Measurement: 10 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
