Datasheet IRLR8503PBF - International Rectifier Даташит Полевой транзистор, N, 30 В, 49 А, D-PAK — Даташит
Наименование модели: IRLR8503PBF
9 предложений от 9 поставщиков N-Channel 30 V 44A (Tc) 62W (Tc) Surface Mount TO-252AA (DPAK) | |||
| IRLR8503PBF International Rectifier | 218 ₽ | ||
| IRLR8503PBF Infineon | по запросу | ||
| IRLR8503PBF | по запросу | ||
Описание: Полевой транзистор, N, 30 В, 49 А, D-PAK
PD- 95095A IRLR8503PbF IRLR8503PbF
· · · · N-Channel Application-Specific MOSFET Ideal for CPU Core DC-DC Converters Low Conduction Losses Minimizes Parallel MOSFETs for high current applications · Lead-Free
HEXFET® MOSFET for DC-DC Converters
D
Description This new device employs advanced HEXFET Power MOSFET technology to achieve very low on-resistance.
The reduced conduction losses makes it ideal for high efficiency DC-DC converters that power the latest generation of microprocessors. The IRLR8503 has been optimized and is 100% tested for all parameters that are critical in synchronous buck converters including RDS(on), gate charge and Cdv/dtinduced turn-on immunity. The IRLR8503 offers an extremely low combination of Qsw & RDS(on) for reduced losses in control FET applications. The package is designed for vapor phase, infra-red, convection, or wave soldering techniques. Power dissipation of greater than 2W is possible in a typical PCB mount application.
- Continuous Drain Current Id: 44 А
- Drain Source Voltage Vds: 30 В
- On Resistance Rds(on): 18 МОм
- Voltage Vgs Max: 20 В
- Рабочий диапазон температрур: -55°C ... +150°C
- Корпус транзистора: D-PAK
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Альтернативный тип корпуса: D-PAK
- Current Id Max: 44 А
- Тепловое сопротивление переход-корпус: 2°C/W
- On State resistance @ Vgs = 10V: 16 МОм
- Тип корпуса: DPAK
- Power Dissipation Pd: 62 Вт
- Pulse Current Idm: 196 А
- Способ монтажа: SMD
- Threshold Voltage Vgs Typ: 1 В
- Voltage Vds Typ: 30 В
- Voltage Vgs Rds on Measurement: 10 В
- Voltage Vgs th Min: 1 В
RoHS: Y-Ex
Дополнительные аксессуары:
- Fischer Elektronik - FK 244 08 D PAK
- Fischer Elektronik - FK 244 13 D PAK
- Fischer Elektronik - WLK 5
Купить IRLR8503PBF на РадиоЛоцман.Цены
