Datasheet IRF130 - International Rectifier Даташит N CH полевой транзистор, 100 В, 14 А, TO-204AA — Даташит
Наименование модели: IRF130
Купить IRF130 на РадиоЛоцман.Цены — от 16 до 3 019 ₽13 предложений от 13 поставщиков Труба MOS, IRF130 Series 100V 0.18Ω 12NC Through Hole N-Channel Power MOSFET - TO-3 | |||
| IRF130 Infineon | 16 ₽ | ||
| IRF130 International Rectifier | 883 ₽ | ||
| IRF130P Samsung | по запросу | ||
| IRF130 Infineon | по запросу | ||
Описание: N CH полевой транзистор, 100 В, 14 А, TO-204AA
PD - 90333F
IRF130 REPETITIVE A ALANCHE AND dv/dt RATED V JANTX2N6756 HEXFET TRANSISTORS JANTXV2N6756 THRU-HOLE (TO-204AA/AE) [REF:MIL-PRF-19500/542] 100V, N-CHANNEL
Product Summary
Part Number IRF130 BVDSS 100V RDS(on) 0.18 ID 14A
The HEXFETtechnology is the key to International Rectifier's advanced line of power MOSFET transistors.
The efficient geometry and unique processing of this latest "State of the Art" design achieves: very low on-state resistance combined with high transconductance; superior reverse energy and diode recovery dv/dt capability. The HEXFET transistors also feature all of the well established advantages of MOSFETs such as voltage control, very fast switching, ease of paralleling and temperature stability of the electrical parameters. They are well suited for applications such as switching power supplies, motor controls, inverters, choppers, audio amplifiers and high energy pulse circuits.
- Continuous Drain Current Id: 14 А
- Drain Source Voltage Vds: 100 В
- On State Resistance: 180 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: TO-3
- Количество выводов: 2
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 14 А
- Current Temperature: 25°C
- Fixing Centres: 30 мм
- Расстояние между выводами: 11 мм
- Количество транзисторов: 1
- Тип корпуса: TO-3
- Power Dissipation Pd: 75 Вт
- Pulse Current Idm: 56 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 100 В
- Voltage Vgs Rds on Measurement: 10 В
Дополнительные аксессуары:
- Fischer Elektronik - AKK 191
- Fischer Elektronik - FK 201SA-3
- Fischer Elektronik - SK 04/50 SA
- Fischer Elektronik - WLK 5
