Datasheet FDV302P-MR - Fairchild Даташит Полевой транзистор, цифровой FDV302P MINIREEL 500PCS — Даташит
Fairchild FDV302P-MR
Наименование модели: FDV302P-MR
48 предложений от 29 поставщиков
MOSFET P-CH 25V 120MA SOT-23. P-Channel 25V 120mA (Ta) 350mW (Ta) Surface Mount SOT-23. Transistors - FETs, MOSFETs - Single
ICdarom.ru
FDV302P
от 21 ₽
МосЧип
FDV302P_D87Z
Fairchild
Hi-Tech Circuit Group
FDV302P
Fairchild
LifeElectronics
FDV302P-NL/302
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, цифровой FDV302P MINIREEL 500PCS
data sheetСкачать Data Sheet
October 1997
FDV302P Digital FET, P-Channel
General Description
This P-Channel logic level enhancement mode field effect transistor is produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors. Since bias resistors are not required, this one P-channel FET can replace several digital transistors with different bias resistors such as the DTCx and DCDx series.
Features
  • Полярность транзистора: P Channel
  • Continuous Drain Current Id: 120 мА
  • Drain Source Voltage Vds: 25 В
  • On State Resistance: 13 Ом
  • Rds(on) Test Voltage Vgs: 2.7 В
  • Корпус транзистора: SOT-23
  • Количество выводов: 3
  • Current Temperature: 25°C
  • ESD HBM: 6 кВ
  • Тип корпуса: SOT-23 (TO-236)
  • Power Dissipation Pd: 350 мВт
  • Pulse Current Idm: 500 мА
  • Reel Diameter: 100 мм
  • Количество приборов в упаковке (ленте): 500
  • SMD Marking: 302
  • Ширина ленты: 8 мм
  • Способ монтажа: SMD
  • Voltage Vgs th Max: -1.5 В
Дополнительные аксессуары:
  • Roth Elektronik - RE901
FDV302PMR, FDV302P MR
На английском языке: Datasheet FDV302P-MR - Fairchild MOSFET, DIGITAL FDV302P MINIREEL 500PCS
