Datasheet MC10EL33DG - ON Semiconductor Даташит Полевой транзистор, P LOGIC-GATE — Даташит
ON Semiconductor MC10EL33DG
Наименование модели: MC10EL33DG
24 предложений от 16 поставщиков
IC DIVIDER DIV X4 ECL DIFF 8SOIC. Counter IC Divide-by-4 1 Element 1 Bit Positive, Negative 8-SOIC. Logic - Counters, Dividers...
MC10EL33DG
500 ₽
MC10EL33DG
727GS
MC10EL33DG
MC10EL33DG
Производитель: ON Semiconductor
Описание: Полевой транзистор, P LOGIC-GATE
data sheetСкачать Data Sheet
MC10EL33, MC100EL33 5VECL ч4 Divider
The MC10EL/100EL33 is an integrated ч4 divider.
The differential clock inputs and the VBB allow a differential, single-ended or AC coupled interface to the device. The VBB pin, an internally generated voltage supply, is available to this device only. For single-ended input conditions, the unused differential input is connected to VBB as a switching reference voltage. VBB may also rebias AC coupled inputs. When used, decouple VBB and VCC via a 0.01 mF capacitor and limit current sourcing or sinking to 0.5 mA. When not used, VBB should be left open. The reset pin is asynchronous and is asserted on the rising edge. Upon power-up, the internal flip-flops will attain a random state; the reset allows for the synchronization of multiple EL33's in a system. The 100 Series contains temperature compensation.
Features Description
http://onsemi.com MARKING DIAGRAMS*
8 1 SOIC-8 D SUFFIX CASE 751 8 1 TSSOP-8 DT SUFFIX CASE 948R 8 HEL33 ALYW G 1 1 8 KEL33 ALYW G
  • Полярность транзистора: P Channel
  • Continuous Drain Current Id: 50 мА
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Корпус транзистора: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Roth Elektronik - RE932-01
На английском языке: Datasheet MC10EL33DG - ON Semiconductor MOSFET, P LOGIC-GATE
