Datasheet MCH12140DG - ON Semiconductor Даташит Транзистор PHASE-FREQUENCY DET — Даташит
Наименование модели: MCH12140DG
26 предложений от 18 поставщиков Микросхема Деталь тактового сигнала, Frequency Detector -40℃ to 70℃ 8Pin SOIC N Tube | |||
| MCH12140DG ON Semiconductor | 568 ₽ | ||
| MCH12140DG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: Транзистор PHASE-FREQUENCY DET
MCH12140, MCK12140 Phase-Frequency Detector
Description
The MCH/K12140 is a phase frequency-detector intended for phase-locked loop applications which require a minimum amount of phase and frequency difference at lock.
When used in conjunction with high performance VCO such as the MC100EL1648, a high bandwidth PLL can be realized. The device is functionally compatible with the MC12040 phase-frequency detector with the maximum frequency extending to 800 MHz. When the Reference (R) and VCO (V) inputs are unequal in frequency and/or phase, the differential UP (U) and DOWN (D) outputs will provide pulse streams which when subtracted and integrated provide an error voltage for control of a VCO. See AND8040 for further information. The device is packaged in a small outline, surface mount 8-lead SOIC package. There are two versions of the device to provide I/O compatibility to the two existing ECL standards. The MCH12140 is compatible with MECL 10HTM logic levels while the MCK12140 is compat
- Рабочий диапазон температрур: -40°C ... +70°C
- Корпус транзистора: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: 8-NSOIC
