Datasheet MTD5P06VT4G - ON Semiconductor Даташит Полевой транзистор, P, D-PAK — Даташит
ON Semiconductor MTD5P06VT4G
Наименование модели: MTD5P06VT4G
14 предложений от 11 поставщиков
P-Channel 60 V 5A (Tc) 2.1W (Ta), 40W (Tc) Surface Mount DPAK
MTD5P06VT4G
от 88 ₽
MTD5P06V--T4G
MTD5P06VT4G
SUV System
MTD5P06VT4G
Производитель: ON Semiconductor
Описание: Полевой транзистор, P, D-PAK
data sheetСкачать Data Sheet
MTD5P06V
Preferred Device
Power MOSFET
5 Amps, 60 Volts P-Channel DPAK
This Power MOSFET is designed to withstand high energy in the avalanche and commutation modes.
Designed for low voltage, high speed switching applications in power supplies, converters and power motor controls, these devices are particularly well suited for bridge circuits where diode speed and commutating safe operating areas are critical and offer additional safety margin against unexpected voltage transients.
  • Полярность транзистора: P Channel
  • Continuous Drain Current Id: 5 А
  • Drain Source Voltage Vds: 60 В
  • On State Resistance: 450 МОм
  • Voltage Vgs Max: 2.8 В
  • Корпус транзистора: D-PAK
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Avalanche Single Pulse Energy Eas: 125mJ
  • Current Id Max: 5 А
  • Тип корпуса: DPAK
  • Power Dissipation Pd: 40 Вт
  • Pulse Current Idm: 18 А
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: -2.8 В
  • Voltage Vds Typ: -60 В
  • Voltage Vgs Rds on Measurement: -10 В
  • Voltage Vgs th Max: -4 В
  • Voltage Vgs th Min: -2 В
RoHS: Y-Ex
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 13 D PAK
  • Fischer Elektronik - WLK 5
  • Roth Elektronik - RE901
На английском языке: Datasheet MTD5P06VT4G - ON Semiconductor MOSFET, P, D-PAK
