Datasheet NID5003NT4G - ON Semiconductor Даташит SMART полевой транзистор, N, 42 В, 1.3 Вт, D-PAK — Даташит
ON Semiconductor NID5003NT4G
Наименование модели: NID5003NT4G
14 предложений от 14 поставщиков
Power Switch/Driver 1:1 N-Channel 20A DPAK
NID5003NT4G
420 ₽
NID5003NT4G
1 124 ₽
NID5003NT4G
NID5003NT4G
Производитель: ON Semiconductor
Описание: SMART полевой транзистор, N, 42 В, 1.3 Вт, D-PAK
data sheetСкачать Data Sheet
NID5003N
Preferred Device
Self-Protected FET with Temperature and Current Limit
42 V, 20 A, Single N-Channel, DPAK
HDPlust devices are an advanced series of power MOSFETs which utilize ON Semiconductors latest MOSFET technology process to achieve the lowest possible on-resistance per silicon area while incorporating smart features.
Integrated thermal and current limits work together to provide short circuit protection. The devices feature an integrated Drain-to-Gate Clamp that enables them to withstand high energy in the avalanche mode. The Clamp also provides additional safety margin against unexpected voltage transients. Electrostatic Discharge (ESD) protection is provided by an integrated Gate-to-Source Clamp.
  • Continuous Drain Current Id: 20 А
  • Drain Source Voltage Vds: 42 В
  • On State Resistance: 42 МОм
  • Voltage Vgs Max: 14 В постоянного тока
  • Рабочий диапазон температрур: -55°C ... +150°C
  • Корпус транзистора: D-PAK
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Avalanche Single Pulse Energy Eas: 400mJ
  • Current Id Max: 20 А
  • Тип корпуса: DPAK
  • Pin Configuration: 1(G), 2(D), 3(S)
  • Power Dissipation Pd: 1.3 Вт
  • Shutdown Temperature: 175°C
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 1.7 В
  • Voltage Vds Typ: 42 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Max: 2.2 В
  • Voltage Vgs th Min: 1 В
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 08 D PAK
  • Fischer Elektronik - FK 244 13 D PAK
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet NID5003NT4G - ON Semiconductor SMART MOSFET, N, 42 V, 1.3 W, D-PAK
