Datasheet NIF5003NT1G - ON Semiconductor Даташит SMART полевой транзистор, N, 42 В, 1.25 Вт, SOT-223 — Даташит
ON Semiconductor NIF5003NT1G
Наименование модели: NIF5003NT1G
NIF5003NT1G
64 ₽
NIF5003NT1G
МосЧип
NIF5003NT1G
727GS
NIF5003NT1G
Производитель: ON Semiconductor
Описание: SMART полевой транзистор, N, 42 В, 1.25 Вт, SOT-223
data sheetСкачать Data Sheet
NIF5003N
Preferred Device
Self-Protected FET with Temperature and Current Limit
42 V, 14 A, Single N-Channel, SOT-223
HDPlusTM devices are an advanced series of power MOSFETs which utilize ON Semiconductors latest MOSFET technology process to achieve the lowest possible on-resistance per silicon area while incorporating smart features.
Integrated thermal and current limits work together to provide short circuit protection. The devices feature an integrated Drain-to-Gate Clamp that enables them to withstand high energy in the avalanche mode. The Clamp also provides additional safety margin against unexpected voltage transients. Electrostatic Discharge (ESD) protection is provided by an integrated Gate-to-Source Clamp.
  • Continuous Drain Current Id: 14 А
  • Drain Source Voltage Vds: 42 В
  • On State Resistance: 53 МОм
  • Voltage Vgs Max: 14 В постоянного тока
  • Рабочий диапазон температрур: -55°C ... +150°C
  • Корпус транзистора: SOT-223
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Avalanche Single Pulse Energy Eas: 233mJ
  • Clamping Voltage Vc Max: 42 В
  • Current Id Max: 14 А
  • Тип корпуса: SOT-223
  • Pin Configuration: 1(G), 2(D), 3(S), 4-TAB(D)
  • Power Dissipation Pd: 1.25 Вт
  • Способ монтажа: SMD
  • Threshold Voltage Vgs Typ: 1.7 В
  • Voltage Vds Typ: 42 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Max: 2.2 В
  • Voltage Vgs th Min: 1 В
Дополнительные аксессуары:
  • LICEFA - V11-7-6-10
  • LICEFA - V11-7
  • Roth Elektronik - RE901
На английском языке: Datasheet NIF5003NT1G - ON Semiconductor SMART MOSFET, N, 42 V, 1.25 W, SOT-223
